fittings to attach standard dishwasher door to cabinet door
mbaettig
by mbaettig » Mon Apr 30, 2007 5:47 pm
Hi I am building my own kitchen, but have standars white goods. I want to find sone way to attache the new cabinet doors to my dishwasher unit so it all pulls open in one. is ther such a product or does this only come with intergrated appliances???? I am in east london any help
If this is possible i would alos like to dio the same for my fridge...
hope someone can help...
thedoctor3
by thedoctor3 » Tue May 08, 2007 12:00 am
Not easy to do as most white goods are designed to finish flush with door fronts under a standard 600mm worktop. By battening the wall and bringing your worktop forward by 75mm, this will give you room to fit a standard hinge & door in front of your applience.
Johnc
by Johnc » Tue May 08, 2007 9:58 am
Remember to leave space for the hinges if you have a full door that opens downwards, i.e. a dishwasher. A 600mm wide space for a normal dishwasher wouldn't be enough as most appliances are around 600mm wide and would not get passed the hinges even if you made the space deeper. I gave ours an 800mm opening, and used 2 x 400mm doors. we did this and used the space for small metal racks either side which we put the dishwasher tablets and salt in.
You will also have to cut & attach the plinth to the doors as opening dishwasher down wouldnt work with a normal plinth, as it would be above the pivot of the hinge.
It is currently Tue Nov 26, 2024 3:54 am
