Hot water tap
gingertom
Hot water tap
by gingertom » Mon May 26, 2008 12:09 am
Hello hope someone can help.. Ive a bathroom basin HW tap that isnt working no water flow, yet the bath HW tap works OK .Ive taken the handle off spindle seems ok and checked for a clearance at the spout Cold water taps in basin and bath working
Any ideas ? much appreciated
by htg engineer » Mon May 26, 2008 9:38 am
When you take the handle off - around the spindle is shaped like a nut, drain the hot water or turn off water via a gate valve etc undo the nut and check the tap washer, they sometimes come off and become lodged in the tap and can stop/restrict the flow.
htg
rosebery
by rosebery » Mon May 26, 2008 10:26 am
and before you do that procure a new one just in case it needs replacing which is much easier to do whilst you have it apart.
They're only a couple of quid.
rosebery
I mean the tap head NOT just the washer.
nitro23456
by nitro23456 » Mon May 26, 2008 2:38 pm
and even before you do that check to see if someone hasnt isolated the tap with a ballofix valve or something similar on the pipe run up to the tap.
It is currently Fri Jan 10, 2025 4:58 am
