electric
james290
electric
by james290 » Thu May 29, 2008 2:58 pm
Hi i have some downlighters in my bathroom and i need to take them out so i can replace the bulb though i cant get them out of the ceiling, could you tell me how to do this.
by sparx » Thu May 29, 2008 9:50 pm
Hi, you should not have to remove fitting to renew lamp(bulb).
If correct bathroom type the front glass is usually held in with a wire circlip around rim, you can see an end of it sticking inwards. squeeze the ends in and remove (glass will come too), then lamp should be reachable.
If still unable to do then grasp both sides of flange and put straight down firmly without jerking and fitting will come down to expose a spring clip each side, squeeze clips against body of fitting and keep pulling, reverse to refit,
regards SPARX
dirtyred619
by dirtyred619 » Thu May 29, 2008 9:51 pm
There should be a clip under the bulb that you squeeze and the bulb will drop down.
It is currently Sat Nov 16, 2024 12:54 pm
