rendering question
blakey
rendering question
by blakey » Thu May 29, 2008 5:51 pm
hello all, when adding waterproofer to the render scratch coat does this also act as a plasticiser to make the mix more manageable or should plasticiser be added as well or can they not be mixed. thanks.........
richm
by richm » Fri May 30, 2008 6:34 pm
Blakey, the waterproofer will make mix more easier to use & I would not advise mixing the two
blakey
by blakey » Fri May 30, 2008 10:26 pm
cheers my friend :D
richm
by richm » Sat May 31, 2008 1:18 pm
If you wet the wall aswell this will also help
It is currently Fri Nov 22, 2024 2:48 pm
