kitchen lighting, fused spur/ mains lighting circuit?
6 posts   •   Page 1 of 1
benny
by benny » Thu May 29, 2008 10:59 pm
I want to change the lighting under my kitchen units to mini fluoresent tubes (low enery 10w slimline ones) in the instructions it says they should be fitted to a plug with a 3a fuse or into a fused switch, the 3 existing lights are wired into the mains lighting circuit via a junction box. Can these be wired staight to the mains in the same way, if not is there a way of wiring them to the existing lighting circuit and using the existing switches?
Thanks Ben
by ericmark » Fri May 30, 2008 11:32 am
fluorescent lights do need fusing but there is no reason why you should not feed the fusing unit from the main lights.
But:-
1) You need to wire to lamp not switch as there are no neutrals in the switch.
2) It will come under Part P look at links in Projects section.
So I would swap junction box for a fused spur unit.
benny
by benny » Sun Jun 08, 2008 11:58 pm
Thanks for the reply, I thought fused sockets were to be used on a ring main or for a spur off a ring main, so its doesnt matter that the powers coming from a lighting circuit, I can keep the existing loop-in system and use a fused socket to connect wire to the fluorecent tube wire to the lighting circuit?
by ericmark » Mon Jun 09, 2008 8:23 pm
I have not mentioned a socket. Looking as Screwfix as an example 29775 MK 13A DP FCU is just a fuse holder and 13479 MK 13A DP Sw FCU also has a switch. Many fluorescent lamps have the fuse build into the lamp. The main thing is to follow manufactures instructions if it says fuse to 3 amp then fuse to 3 amp. I think that the 6 amp which most lighting circuits are limited to is most likely enough but I can’t really tell you that is enough in case there is something which I am unaware of. The rules which we follow are contained in a big red book and to tell you all the rules would take a lot longer than I can spend on here. You would not connect a normal 13 amp socket to a lighting circuit although there are special sockets and plugs designed for lights. I do not like DIY but neither do I like Part P which rather than making things safer has resulted in forcing things underground but there is good reason for making kitchens a special location and before continuing you need to do a risk assessment is the risk to your family worth the money saved?
All best Eric
BadBoab
by BadBoab » Fri Aug 06, 2010 7:53 am
ericmark wrote:fluorescent lights do need fusing but there is no reason why you should not feed the fusing unit from the main lights.
But:-
When you say Part P Projects section, do you mean e actual Part P of the Building Regs or is this content of a Part P course? Thanks Boab
by ericmark » Sat Aug 07, 2010 2:18 am
I was referring to building regulations there is no Part P qualification. Electricians can pay an annual fee to self certificate their work and become a member of a "Competent Persons Scheme" which means they don't have to inform the LABC before starting or pay their high fees which seem to start at £100+.
As a result any work less than £200 which is notifiable is not really worth doing as DIY.
It is currently Mon Nov 25, 2024 4:01 am
