PAINTING OVER EXISTING SILK EMULSION
BMF360
by BMF360 » Fri May 30, 2008 10:29 am
[size=18][b]hi does anyone have any hints on how i can paint over existing silk emulsion, i have a large room where i have removed the wall paper and its backing and left the exposed wall with partly painted walls and some down to the plaster, i have tried to paint over the walls with some new matt paint and it is blistering or leaving a very rough finish. the walls were very smooth prior to the new paint going on.
hope someone can help
many thanks[/b][/size]
rosebery
by rosebery » Sat May 31, 2008 11:59 pm
Matt over silk NEVER works. It ALWAYS cracks.
Either line it first with 800 grade lining paper or use an oil/spirit based white undercoat first.
Then paint over.
chris_on_tour2002
by chris_on_tour2002 » Fri Jun 06, 2008 12:11 am
it's also possible (and quite likely) that there is some residual wallpaper paste from the paper that you removed on the paint. a bit of a job to get every trace of it off and it won't take a paint. lining paper is the best solution.
It is currently Tue Nov 26, 2024 12:34 pm
