bonding
zider
bonding
by zider » Fri May 30, 2008 12:15 pm
hi
got an extension to plaster,building inspector wants two coats of bonding over themalite blocks before the finish coat can be apply .is it best to let each coat dry,pva before skimming or is it best to when almost dry.any advise would be welcome :?
richm
by richm » Sat May 31, 2008 2:12 pm
Personally, if it was me I would use sand/cement backing on an extension & then you would only need to apply one coat & then skim
It is currently Fri Nov 22, 2024 3:09 pm
