HOW DO I WIRE A 2 WAY SWITCH?
IAN TURTON
by IAN TURTON » Fri May 30, 2008 11:59 pm
I WANT TO PUT A NEW LIGHT IN THE GARAGE AND HAVE A SWITCH AT BOTH DOORS I UNDERSTAND HOW TO WIRE ONE IN BUT THE SECOND SWITCH IS PROVING A PROBLEM. ANY HELP WOULD BE GREAT :
by ericmark » Sat May 31, 2008 2:24 am
Using 3 core and earth cable with brown sleeving on the black and gray cores you connect all the terminals like to like. i.e. L1 to L1 and common to common and L2 to L2. Which ever switch the switch cables from the light arrive at these will go to L1 and L2.
Note:- This is not the way shown in things like Wikipedia which will show school boy method with the switch wires going to the two commons this method is not used because it requires a junction block in the switch.
All best Eric
It is currently Fri Jan 17, 2025 10:58 pm
