DRIPPING KITCHEN TAP
rob uttley
by rob uttley » Sun Jun 01, 2008 11:04 am
hi. we have a kitchen mixer tap that keeps dripping. i have taken off valve from the hot tap and there is a constant drickle of water leaking through remainder of tap even when the water is turned off at the mains.
can anyone help, please.
nitro23456
by nitro23456 » Sun Jun 01, 2008 1:07 pm
you have to turn your hot supply off separately if you have a gravity fed system.
stevenc1603
by stevenc1603 » Mon Jun 02, 2008 12:24 pm
Even though you have turned the water off at the mains there will be residual water pressure in the pipework in the house which will run out if you remove a tap body. This is normal and is not the cause of your leaking tap.
Mac-the-Wrench
by Mac-the-Wrench » Tue Jun 03, 2008 2:05 am
Have you changed any washers? It could be as simple as it not being tight enough. I got a call-out for a similar problem, and that's all it was. I had to use a 22mm compression spanner to tighten it because all others were too fat to fit.
It is currently Fri Nov 22, 2024 7:39 am
