hot water keeps stoping and returning
lyndon12
by lyndon12 » Mon Jun 02, 2008 4:22 pm
having replaced a ball cock in header tank on my old gravity fed system with imersion tank my hot water flow is slower and sometimes stops, seems to be a delay in the header to imersion tank, all i did was isolate and drain header and imersion as i also replaced a hot water tap, then turned water suply back on, header filled back up and everything seemed ok, but hot flow is slow and perodicaly stops and then returns, have i an air lock??, if so what can i do?, would appreciate any help, not a plumber as you have guessed!!!, cheers
rosebery
by rosebery » Mon Jun 02, 2008 9:26 pm
Sounds like it.
See https://www.diydoctor.org.uk/projects/curingairlock.htm in the projects section.
Dave From Leeds
by Dave From Leeds » Tue Jun 03, 2008 1:22 am
Try opening one of your hot taps and leave it open for about 5 minutes. If the problem is an airlock in the cylinder this may allow the head of water in your header tank to push it through.
It is currently Fri Jan 10, 2025 4:08 am
