lighting
charlie58
lighting
by charlie58 » Mon Jun 02, 2008 11:01 pm
Can someone advise me please. I want to install a new light in a garage that i am partitioning. I cannot easily access the existing wiring. There is an unused socket off aring main in the area i would ideally like the light to be. Can i use this ring main wiring in conjunction with a fused switch and ceiling rose to install a new light? Thanks for any advice. Charlie
by ericmark » Tue Jun 03, 2008 11:04 am
Yes it is quite common to use a switched fused spur with fuse no bigger than 5 amp to feed a lamp rather than install new consumer units in a garage. Only thing to be aware of is what happens if the power trips. If for example you had an accident with a power tool would it then leave you in darkness and so in extra danger? You may need an emergency light to make it safe.
It is currently Sat Nov 23, 2024 7:41 pm
