Stopping hot water
Dylfin
Stopping hot water
by Dylfin » Tue Jun 03, 2008 9:37 pm
Hi, trying to change a mixer tap in the kitchen. Got an indirect storage cylinder upstairs. Is there anyway I can change tap without draining the cylinder? Can't find a stop valve in airing cupboard.
Rico
by Rico » Wed Jun 04, 2008 10:50 am
Hi there,
Yes there is. Identify the cold supply to the cylinder from the CWSC and stick a bung in it to create airlock.
Rico
nitro23456
by nitro23456 » Wed Jun 04, 2008 2:38 pm
its very unlikely there isnt anything to turn it off.
Its normally a gate valve (big red tap) in the airing cupboard or an isolation valve in the pipework leading down from the loft into the bottom of the cylinder.
Even if there isnt, you dont have to 'drain' the cylinder - just turn off mains to the CWST in the loft via stop cock under sink, make sure it has worked and the storage tank isnt filling, and turn on the cold and hot taps to all sinks until the water stops....
There will still be water in the cylinder, but no head from the loft to push it out.
Even easier there may be a ballofix type valve under you sink on the pipe run up to the mixer. If there is all you need to do is close this for the hot.
Dylfin
stopping hiot water
by Dylfin » Thu Jun 05, 2008 10:03 pm
Thank you all for the advice, I've changed the tap.
cheers.
It is currently Fri Nov 22, 2024 2:24 pm
