Earth against Wall - Correct Rework
simonwar
by simonwar » Wed Jun 04, 2008 7:07 am
I have earth against a wall, after a big flood, water eventually penetrated through the walls.
I am going to dig it out, about 2 feet deep, and put in a damp proof membrane against the wall, line the base with chippings, 1 to 2" and I was told to lay in a pipe before covering over with the earth again.
Q. Is there a special type of pipe for this or do i use a drainpipe and pepperpot the top of it with holes?
Q. Do I connect the pipe into the drainage system?
Any help appreciated.
Thanks, S.
tucny
by tucny » Sat Jun 07, 2008 3:57 pm
how high are the ground levels?
What are you doing inside regarding the damp?
It is currently Fri Dec 27, 2024 2:35 am
