CAN YOU HELP, HOW CAN I REMOVE PLASTIC PLASTER BOARD PLUGS?
oramnico
by oramnico » Wed Jun 04, 2008 4:31 pm
I HAVE MOVED INTO A HOUSE WHERE THE GUY WAS PLASTER PLUG MAD, ALL THE WALLS ARE PLASTER BOARD SO ALL SCREWS AND NAILS NEED TO BE PUT IN WITH PLASTER BOARD PLUGS, THEY ARE EVERY WHERE, HOW CAN I GET THEM OUT EASILY WITHOUT DAMAGING THE WALL?
richm
by richm » Wed Jun 04, 2008 6:37 pm
I use one of those wide scrapers from any diy store with the blade that looks like a razor blade & just swiftly cut them off flush & then fill the holes remaining
stevenc1603
by stevenc1603 » Thu Jun 05, 2008 10:16 am
Easiest way would probably be to push them through then patch over the resulting hole. If you try to pull them out there's a chance more damage could be done.
chris_on_tour2002
by chris_on_tour2002 » Fri Jun 06, 2008 12:07 am
run a sharp stanley knife around the bit that's protruding then fill over the hole.
It is currently Fri Nov 22, 2024 2:44 pm
