3 way lighting switch
aries1950
by aries1950 » Wed Jun 11, 2008 6:14 pm
I am in the process of updating my home, in my hall I have 3 way lighting and I want to remove the middle switch, the wire colours are: two yellow,two blue and three red which are together in a connector block, any help would be welcome thanks
by ericmark » Thu Jun 12, 2008 11:52 am
The three red seem odd, normally there would only be two. As a result I may be wrong in your case. But normally you would connect yellow to yellow and blue to blue. When removing any electrical item either you most leave something like a blanking plate to show where it was or remove completely. There are "Permitted Zones" for wiring once you remove the ID to show where it ran it is no longer a permitted zone.
aries1950
by aries1950 » Thu Jun 12, 2008 7:02 pm
hi ericmark
thank you very much for the information, on closer inspection there is only 2 red! my mistake
(':oops:')
Embarassed
It is currently Fri Jan 17, 2025 10:59 pm
