combi boiler
DIYMIKE
combi boiler
by DIYMIKE » Thu Jun 12, 2008 10:49 pm
I have managed to @up@ the pressure on my combe boiler to 2.5 bar. I think this is too high and want to reduce it to 1.0 bar. How do I do that??
Rico
by Rico » Fri Jun 13, 2008 10:27 am
Hi Mike,
Attached to drain valve on any downstairs rad, should all have one and let the reuiqred amount out from there.
Rico
Steve the gas
by Steve the gas » Sat Jun 14, 2008 7:31 am
Or you can empty some water out of a rad bleed valve.
by htg engineer » Sat Jun 14, 2008 11:27 am
Vent radiators, any air will be replaced with water - may be enough to drop the pressure,
Drain from a suitable drain point, near boiler or on radiators or pipework,
Last resort - as opening can sometimes cause them to pass. Crack open the PRV.
Htg
It is currently Fri Nov 22, 2024 2:38 pm
