Laying Solid Wood
Joiner_Mike
Laying Solid Wood
by Joiner_Mike » Fri Jun 13, 2008 10:10 pm
Im thinking of laying around 100 square metres of solid oak grade A&B to a concrete sub floor. The mostiure content has been checked and is fine to lay on.
What would be the best method? Using Sika T54 glue or by using battons and secret nailing? Does it sound hollow on battons? Please don't suggest floating floor cos they always create expansion problems. Ive fiited about 50 solid wood floors.
Are they any other methods?
Ive used skia which is really good glue but it's exoensive about £90 / 10 square metres.
Any advice from experienced floor fitters?
floor-sanding-man
by floor-sanding-man » Fri Jun 27, 2008 5:52 pm
Hi Mike
For me anything over a 6:1 ratio width to thickness I would mechanicaly fix. The Sika T54 is very good but as you say ouch expensive. I used to think the solvent adhesives were good but I got fed up with the headaches, I have been using Bona R850 recently which I found very good, still expensive but not as bad as the Sika. 15kg tub for about £70 which I found good for about 14-15m2.
Still not so sure of liquid batton systems, I still want a full stick down system.
Regards
Sandy Man
It is currently Sat Nov 23, 2024 4:26 pm
