by Skids »
Sat Jun 14, 2008 10:44 pm
Hi arriell,
When you say 'just started' I assume you mean this has never happened before.
If you are mains fed then there is a likelihood that the water undertaker (supplier) may have adjusted the pressure which would have had a knock on affect with your pressure,
Turn your stopcock (should be under the kitchen sink?) down ½ a turn and see if there is a difference.
Phone your water undertaker and ask then if there has been a change in the pressure in your area.
Regards
Skids
