FITTING A CORNER SINK, POSITION FOR WORKTOP JOINTS
Ask questions and find answers on a range of subjects relating to self build projects
powerfulpierre
by powerfulpierre » Wed Jun 18, 2008 10:40 am
CORNER SINK by Sauber, two s'steel bowls joined at right angles, laminate worktops, where do I put the worktop joint to avoid cutting most of it away? The corner is not a diagonal setup, just the normal right angle between the worktops. Any suggestions?
kayliekitchen
by kayliekitchen » Wed Nov 19, 2008 7:51 am
If you Google "bathroomandkitchenguide.com" you may find a solution
TheDoctor5
by TheDoctor5 » Wed Jan 28, 2009 10:32 am
It is currently Mon Jan 06, 2025 8:57 pm
