Double Light switch into two singles?
mdemetri2
by mdemetri2 » Thu Jun 19, 2008 11:51 am
Hi there,
Grateful for some advice and info here. I currently have a double light switch that operates the light in the living room and the light at the top of the stairs (there is also a single switch at the top of the stairs to control the light in the upstairs landing). Hope this makes sense so far....
What I would like to do is create to single switches from this double switch so that I can have a dimmer for the living room and a normal switch for the upstairs landing plus continue to use the upstairs light switch also.
First of all is this possible? And secondly if I try do this myself is there any way that I could damage the wiring if I wire it all up incorrectly, as there are quite a few wires behind the double switch.....
Many thanks in advance.
mdmemetri2
by ericmark » Thu Jun 19, 2008 11:25 pm
I think you can get a grid switch to combine a dimmer and two way switch on the same plate.
And of course incorrect wiring will likely cause damage depending what is done incorrect.
shaun250
by shaun250 » Wed Jul 02, 2008 3:09 pm
[quote="ericmark"]I think you can get a grid switch to combine a dimmer and two way switch on the same plate.
And of course incorrect wiring will likely cause damage depending what is done incorrect.[/quote]the easiest way out is to change the switch with a two gang dimmer. providing that the back box is deep enough.
It is currently Thu Jan 30, 2025 9:06 pm
