DOT AND DAB
martinhines
DOT AND DAB
by martinhines » Thu Jun 19, 2008 7:40 pm
HI
Ive taken old tiles of the bathroom walls one of the walls is in poor condition down to the base plaster quite dusty. I am considering dot and dab ive never done this before it is my intention to tile the wall after could some one give me a brief explanation (start at bottom work up etc). How long to dry etc. The wall is only 2meters by 2.8 meters
regards
martin
kbrownie
by kbrownie » Fri Jun 20, 2008 1:17 pm
Hi martinhines,
firstly if you intend to dot'n'dab this wall you need a sound surface to work on so the adhesive will bond.
Basics tips are
mix your adhesive as instruction on bag, wet wall down and board where dabs are going.
Dabs about every 10 or 12 inch apart. start at edges of board( i put them on the board some mark the wall and dab on to wall)
Place board on wall and tap with straight edge to get good purchase to wall,
repeat with next board, trying to keep them level and straight with each other especially at the joint.
the method will change depending board size, i always use 8x4's
You need a level and a straight edge, hammer, tape, stanley knife, etc..
KB
It is currently Wed Nov 27, 2024 10:14 pm
