Replacing three port valve
mikegm
by mikegm » Wed Jun 25, 2008 12:59 pm
Apart from replacing the synchronous motor, could anybody advise on whether or not when replacing the valve body itself, the system should be drained down first? (or at least the primary circuit)
plumbbob
by plumbbob » Wed Jun 25, 2008 11:39 pm
You will need to drain down unless the expansion and feed from the header tank can be successfully capped and you can cope with a fair amount of water escaping from the pipe.
Unless you are prepared to get wet, then draining is needed.
It is currently Fri Jan 10, 2025 9:48 am
