Fixing Plasterboard, Battens and Insulation to brick
LeSteve123
by LeSteve123 » Fri Jun 27, 2008 10:36 am
I'm looking find a suitable method to fix insulation to the walls in my garage conversion...
Outer leaf 100mm brick wall (inside painted with bitumen)
45mm Celotex (no cavity)
25mm x 47 battens at 600 centres
1000 gauge vapour control layer (polythene)
12.5mm plasterboard
(this gives the walls a 0.35 U value)
Building control are asking
"What is the proposed fixing? It should be similar to those used in timberframe projects."
I'm also wondering what the fixing distances should be?
Regards
Steve
It is currently Thu Nov 28, 2024 6:28 pm
