by EyeTry »
Sun Jun 29, 2008 12:21 pm
Don`t confuse the silicone lubricant (that allows one part to slide through the rubber grommet / seal / joint) with silicone sealant (mastic) that you can run around the joint.... . And don`t get them on the same place, they don`t work together.
BTW - Did you give the assembly a little "wiggle" to settle the two into alignment, ie.e. so they are not twisted or at a slight angle before fastening any screws or bolts. Good luck, EyeTry
