No Hot Water at all!!
mirrorimage
by mirrorimage » Sat Jun 28, 2008 1:52 pm
Recently, the hot water in my home has stopped altogether. Both the immersion and the heating system in the house now doesn't heat the water. I've check the fuse, and it isn't that.
Going by your Water Systems Project, it seems that I have an 'Indirect Cylinder'.
On the cylinder, there are two pipes which are hot... I think (again, going from yourwater systems project) that they are the 'Incoming the cold feed', and the 'flow from boiler' pipes. (The flow from boiler pipes is much hotter than the incoming cold feed)
The rest of the pipes are cold.
Is there anything I'm able to do? Could it be something I could fix?
Please let me know.
Many thanks
It is currently Fri Jan 10, 2025 1:30 pm
