Power shower - really bad smell from water
KerriBlue
by KerriBlue » Mon Jun 30, 2008 3:28 pm
Has anyone come across this ? _ I have a bath jacuzzi shower combination that are fed by a twin pump (watermill)
Although I have used steralising tablets and special jacuzzi cleaner for hours on end there is a really bad smell from the water coming out of the taps or shower head. especially as the weather get warmer. Could this be somthing in the pump itself ?
plumbbob
by plumbbob » Mon Jun 30, 2008 9:16 pm
It is unlikely the pump is at fault as it only contains a nylon impeller in a metal or plastic housing.
Have you inspected the header tank/s in the loft to make sure the lids are on correctly and no debris has collected inside?
KerriBlue
by KerriBlue » Mon Jun 30, 2008 10:15 pm
Checked it - ok . But looking closer I now realize the smell is coming from the bath plug hole. I will put bleach or something stronger down. Thanks for the quick reply
EyeTry
by EyeTry » Mon Jun 30, 2008 11:02 pm
Just a thought - do you twist the jet nozzles to different positions / angles to ensure the cleansing agents get to those parts?
There is a fair old pressure being pumped to the jacuzzi nozzles so have you checked to make sure there is no seepage from any joints in the circuitry - especially behind the bath panels? Having said that I would have expected there to be a smell all the time - a damp, musty smell... . Good luck anyway, EyeTry
It is currently Thu Nov 21, 2024 7:59 pm
