CONCRETE LINTEL
SS003C
CONCRETE LINTEL
by SS003C » Thu May 03, 2007 5:07 pm
hi,
this is my first post in this forum and hope somebody can help?
im in the process of building my garage and im at the stage where i need a lintel.
basically i need a 11ft lintel and would like to make it my self using concrete.
what i need to know is what mix i will need..also is there any particular type of reinforcing steel ..
thanks in advance
steve
thedoctor
by thedoctor » Sun May 06, 2007 10:43 am
Steve lintels are required to be reinforced with steel, the size of which must be specified in the building regulations as must the type & size of lintel you use. This is not a DIY job without the correct specification from an architect or building inspector. Once you have that and you have learned how to tie steel properly you could carry on.
It is currently Fri Jan 31, 2025 2:08 am
