PROBLEM WITH DOOR SIZE
ewan
by ewan » Thu Jul 03, 2008 2:38 pm
I have a built in fitted wardrobe, as part of the house and it has all the wood facings around it.
I had 2 sliding doors on this which fell apart and I really now want to replace them with either louvre doors or internal doors. I would need two.
Basically, the space looks just like an internal door frame ( without the door ).
the problem is the size. The height is 197.5 cm ( 70.67 " ) and the width is 50cm ( 19.69 " ).
The problem seems to be that no door i find can seem to be cut to a width of 50cm , as I have been told it would start to dislodge the joints in teh wood etc.
Any advice most appreciated.
DUDE DIY
by DUDE DIY » Sat Jul 12, 2008 7:53 am
try this web site....spaceslide.co.uk
chris_on_tour2002
by chris_on_tour2002 » Wed Jul 16, 2008 5:51 pm
could you make a door? using 2"x1" for the frame and hardboard cladding it would cheap and relatively quick. worth a try even for the inexperienced. not disastrous if it fails and you just resume your search! good luck
It is currently Sun Nov 24, 2024 2:39 am
