loose tap cover
6 posts   •   Page 1 of 1
stronach
loose tap cover
by stronach » Wed Jul 09, 2008 5:49 pm
I have a bathroom hot tap with a sort of domed cover. It is 13 years old, the top, or whatever it is connected to underneath is loose. I cannot see how to remove it. Can anybody assist please. Thanks.
bobplum
by bobplum » Thu Jul 10, 2008 6:47 pm
hi do you want to remove the whole tap from the bath,if so it will be secured underneath with a locking nut,dissconnect the pipe work and buy a back nut spanner to loosen nut or is it the top half of the tap you wish to remove it may help if you can supply a photo
bob
stronach
loose tap cover
by stronach » Fri Jul 11, 2008 3:13 pm
I just want to get the tap cover off to see what is loose underneath. Thanks for trying to help.
PP100
by PP100 » Sun Jul 13, 2008 1:57 am
Apologies if you've tried this, but you should simply be able to pop off the top of the tap with a thin headed screwdriver. This should expose a screw holding the tap handle onto the body. Undo this and you should be able to get in.
Andy
by htg engineer » Sun Jul 13, 2008 6:31 pm
Normal ways to remove tap heads.
The caps with the letters C or H or Red or Blue covers pop off with a screwdriver and normally reveal a screw which can be undone and the tap handle/housing removed.
Older styles - the same as above but this only removes the tap handle then you can unscrew the dome that sits over the spindle by hand (or grips over a cloth).
hope this helps
htg
stronach
by stronach » Sun Jul 13, 2008 7:36 pm
Thanks for all assistance, will try the suggestions.
It is currently Fri Jan 10, 2025 1:48 pm
