by htg engineer »
Sat Jul 12, 2008 5:09 pm
If you can I would go for a pressurised Condensing Combination Boiler system. This removes the need for tanks and reduces the amount of pipework required.
Open vented means the system is not pressurised - not filled from cold mains. The heating system fills via a tank in the loft. A pressurised system has a pressure relief valve. A open vented system has an open vent for the safe discharge of excess heat/water.
The down sides of an open veanted system are:
More pipework
Storage tanks, take up room/storage space. Can freeze if not protected.
Ball valves require changing
Airlocks, if you drain the system. it can take hours even days to sort problems out
Blocked cold feeds (over years)
If the upheaval of each room is too much, you have 2 choices:
1) fit a new combi boiler leave the old pipework, fit TRV's to radiators pressurise and and see what happens, . It may be ok, the pipework may be sound. I have seen installations like this that have no or very few problems.
2) fit a system boiler, this will require new cylinder etc etc. I imagine with your system pipework being 40 yrs old - your current system will not fully pumped so there will be pipes that will have to be altered and some will not be re-used.
While still comforming to regulations, open vented systems are not advised, and very rarely installed. The sealed system (pressurised) is the modern system and if installed properly will give less problems.
hope this helps
htg
