Yet another shower leak
GeorgeSW
by GeorgeSW » Fri Jul 11, 2008 2:38 pm
This time it's from underneath the bath tap, above the shower. I did think of taking a spanner and attempting to tighten the tap to the bath tub or attempt to replace the seal between the tap and the bath tub but as the D in DIY in my case stands for distroy, I'm not sure what to do.
Is there some sort of specialised tap to bath sealent I can get instead?
Also are those new plastic hinged strips any good, the one you can use in place of silicon sealent?
George
by htg engineer » Sat Jul 12, 2008 8:18 pm
Most taps come with a rubber washer, this makes the watertight seal between the tap and the bath. You need a new rubber seal, you can probably buy them if not get a square of rubber and make your own.
Replacing the washer means removing the tap. But will guarantee a watertight seal.
htg
It is currently Wed Nov 27, 2024 5:33 am
