Wallpaer edge curling
Lazy Larry
by Lazy Larry » Sat Jul 12, 2008 8:27 pm
I have an almost rubbery, very thick, paper on my kitchen walls. It has probably been on for thirty years and had slight edge looseness when I moved in. Emulsioning to cover the horrible pattern has caused the top edge to curl a bit. I have stuck the edge down with border paste, having softened the paper with a hairdryer, and left to dry with a piece of wood weighted by leaning a ladder against it. It still curls after a while. Is there a stronger adhesive I can try? I'm not overly worried about damage if I ever strip the paper as the wall is a bit rough anyway further down.
mistcoat
Re: Wallpaer edge curling
by mistcoat » Tue Jul 29, 2008 10:20 pm
[quote="Lazy Larry"]I have an almost rubbery, very thick, paper on my kitchen walls. It has probably been on for thirty years and had slight edge looseness when I moved in. Emulsioning to cover the horrible pattern has caused the top edge to curl a bit. I have stuck the edge down with border paste, having softened the paper with a hairdryer, and left to dry with a piece of wood weighted by leaning a ladder against it. It still curls after a while. Is there a stronger adhesive I can try? I'm not overly worried about damage if I ever strip the paper as the wall is a bit rough anyway further down.[/quote]
Just strip it off Lazy Larry and get some fresh new stuff on your walls. It's 30yr old paper dammit... lol
Lazy Larry!!!
mistcoat
It is currently Tue Nov 26, 2024 10:22 am
