Laying different sized pavers
Ausinneed
by Ausinneed » Fri May 04, 2007 12:12 pm
Can anyone help with a design to lay two different size and coloured pavers? My old size paver is 190 x 190 mm and the new pavers are 200 x 200. What design could I use to marry the two different sizes? Many thanks Annette
thedoctor
by thedoctor » Sun May 06, 2007 10:35 am
Can't be explained in the forum Annette, you need to get some graph paper and lay it out. The simplest explaination can only be to have a row of the larger then a row of the smaller with the joints widened slightly to make sure the rows finish in the same place. Not very exiting but easy to explain.
Ausinneed
by Ausinneed » Mon May 07, 2007 11:35 am
Thank you Doc, this is a wonderful site. Your help is much appreciated. :D
It is currently Fri Jan 31, 2025 1:57 am
