Laminate Flooring
James123
Laminate Flooring
by James123 » Tue Jul 15, 2008 12:20 pm
Is there any need to lay newspaper between the floorboards and the 2mm foam underlay before laying the laminate tiles on top? I am thinking back to rubber underlay sticking to floorboards when laying a carpet
alexpowers
Laminate
by alexpowers » Thu Jul 24, 2008 3:39 pm
you dont need the newspaper but the 2mm foam has its use's
it acts as a suppressor as the laminate "floats" above the sub floor think jam in the sandwich!!! also it helps with sliding the laminate in place when fitting.
Hope this helps :)
It is currently Sat Nov 23, 2024 5:55 pm
