Cold feed problem to sower pump
martinh1234
by martinh1234 » Thu Jul 17, 2008 9:25 pm
Hi (my first post). I am currently converting my loft, which includes a new bathroom (with shower). I intend to use a negative head pump, the hot feed to the pump is no problem from the top of the hot water cylinder via a surrey flange, but the cold water storage tank is miles away an inacccessable from the airing cupboard, where the pump will be sited. Someone (heating engineer) suggested tapping into the cold feed to the hot water cylinder. The worry is if I do this, when both sides of the pump are running, won't it drain the hot water cylinder too quick, or won't the pump have a fight with the hot water cylinder over who gets the cold water first!?! All other outlets are mains fed, so no other choice to pick up a cold feed. Any ideas please? Martin H
Skids
by Skids » Fri Jul 18, 2008 9:52 pm
Find mains feed tap into it, run a pipe up into the room:
1. Fit an electric shower
2. for the basin hot tap fit a, ‘Ariston 10lt multipoint unvented under sink heater’
it needs a cold feed, out to a standard hot tap, needs a tundish overflow to drain
this set up will not affect the system that feeds the house.
All the best
Skids
It is currently Mon Dec 02, 2024 10:41 pm
