Help Needed
han_murray
Help Needed
by han_murray » Fri Jul 18, 2008 11:24 pm
Please can someone advise me if i sand a wooden floor first or if i fill in the gaps first before sanding it with a hired sander?
thanks
alexpowers
Hope this helps
by alexpowers » Thu Jul 24, 2008 2:57 pm
Start by giving floor a good sweep, then run your hands over floor feeling for raised nail heads, knock them in and repair any visible damage (loose boards etc) Then give floor first sand - collect some sawdust in to a jar and mix it with PVA glue and then use as a filler filling as you go, each time you go over floor with sander you'll uncover more holes !!!
(because PVA dries clear the holes when filled and cured / sanded dissappear.
:D
It is currently Sat Nov 23, 2024 5:54 pm
