Sloping upstairs wooden floor
williamg
by williamg » Sun Jul 20, 2008 9:03 am
I have a sloping upstairs wooden floor caused by a gable end problem that has been rectified. The floor is only 3cm out of true over the length of the room in one direction and the joists, although old, are solid and safe as is the new brickwork. Lifting the boards and running new joists alongside the old and relaying the floorboards is obviously a long hard job. Is it possible to use (or make) a form of self leveling compound to use on top of the wooden floorboards, then tile on top for a modern look?
alexpowers
Weight issue
by alexpowers » Thu Jul 24, 2008 3:26 pm
Need to be carefull with the weights you're loading onto the flooring,
If it was me I'd cut a roofing batten down to the 30mm and lay against the gable wall then get a long straight edge and put at a right angle to it,
then rip more battens down grading to other side of room, pin down and board over, sounds harder than is ask me if unclear and Ill be more specific.
second way
locate top of joists into Gable wall dig out 50mm above joist go downstairs jack up with acro's and scaffolding board fill lift gap underneath with blue slate - make good.
Second option better to call a pro :)
Hope this helps
williamg
my sloping floors
by williamg » Tue Jul 29, 2008 2:38 pm
Thanks to the authors of both answers to my query, very helpful. Iit is what I was expecting, no quick fix but either way would obviously sort it out!! Thanks again!!!!
It is currently Sat Nov 23, 2024 5:33 pm
