Noisy Central Heating
Richy G
by Richy G » Wed Jul 23, 2008 8:09 am
I have a oil fired central heating system but once the heating has been running for about 2 - 3 hours i get a increasingly loud vibration through mainly 2 of the down stairs radiators which can be stopped by twisting the rad stat but normally returns later.
I have checked the flow direction is correct.
Any ideas would be much appreciated.
by htg engineer » Thu Jul 24, 2008 10:59 am
Could just be something as simple as the radiator valves, try openning fully - if this solves it I would replace the radiator valves.
You say the radiator stat - do you mean TRV's ? if after 2 or 3 hours the other radiator valves close as the temperature is reached, it may just be that the vibration is the force of the water/pump against the other valves. As if you have 10 rads and 8 shut down, you have 2 taking the force of all that water.
Make sure you have a bypass fitted - or at least one radiator with 2 x lockshield valves.
hope this helps
htg
Richy G
Many thanls for your help
by Richy G » Thu Jul 24, 2008 1:12 pm
[quote="htg engineer"]Could just be something as simple as the radiator valves, try openning fully - if this solves it I would replace the radiator valves.
hope this helps
htg[/quote] :D
by htg engineer » Thu Jul 24, 2008 9:41 pm
Any help ?
htg
Richy G
by Richy G » Fri Jul 25, 2008 7:54 am
[quote="htg engineer"]?????
Any help ?
htg[/quote]
Many thanks for your help - i plan to have a look at the weekend, from what you said it makes a lot of sense why the problem only occurs after the heating has been on for a few of hours.
