chain cutter for 100mm clay drainage
mortarboard
by mortarboard » Fri Jul 25, 2008 11:17 am
I need to cut an existing 100mm clay drainage pipe in the ground and have been offered a "chain cutter". Does anyone know if this will work on this type of pipe and how easy it is to make a cut with them?
Steve the gas
by Steve the gas » Fri Jul 25, 2008 7:35 pm
I would use a diamond blade for that.
Freeman
by Freeman » Fri Jul 25, 2008 8:33 pm
Never used one, but I have used a 9" angle grinder fitted with a stone cutting blade in, to cut clay pipe.
by htg engineer » Sat Jul 26, 2008 5:06 pm
Angle grinder. Let the grinder do the cutting don't apply too much pressure or the pipe will break.
htg
mortarboard
by mortarboard » Sun Jul 27, 2008 9:40 pm
Thanks everyone - went with the 9" grinder. Two clean cuts and a successfully re-routed drain:
There are some pictures of the project at http://www.tensquaremetres.com/drains/installation.html
It is currently Fri Nov 22, 2024 9:11 am
