outdoor lights
Bowlesey
outdoor lights
by Bowlesey » Sat May 05, 2007 9:31 am
I am fitting a 500w outdoor security light to an existing outdoor light circuit ( switch is indoors ) which is currently operating a simple 60w bulkhead type fitting outside.
The house is new so presumably all electrics are to current regs etc.
my questions are:
am i ok using 1.00mm twin and earth cabling, as 2 lights will run together?
what is best way of connecting new light wiring into the circuit? e.g is 16 amp connecting block ok?
cheers[/b]
by sparx » Sun May 06, 2007 7:11 pm
1.00 mm will be OK for your Part P registered electrician to loop into second light, using 5A connectors inside original light, so long as well away from heat of lamp!
Regards APARX
It is currently Wed Jan 08, 2025 3:00 pm
