Flow lower with mixer tap installed?
tobiwan
by tobiwan » Mon Jul 28, 2008 6:58 pm
Have just changed two normal bath taps for a shower mixer tap.
The flow seemed quite fast before, and still is on the bathroom sink taps but is a lot slower from the mixer and is not enough for the shower to work.
Is it just that there isn't enough pressure to run a shower mixer or have I done something wrong?
by htg engineer » Tue Jul 29, 2008 9:45 pm
Type of hot water system ?
If you haven't restricted the flow - by leaving isolation valves slightly closed, using flexi hoses etc etc then it's probably not enough pressure to run a shower.
htg
chris_on_tour2002
by chris_on_tour2002 » Wed Jul 30, 2008 11:58 am
are you using flexi connectors with a smaller bore than previous? is there a kink in the flexis? how is your water pressure generally?
how much head do you have to run the shower? did you have a shower previously?
more info reqd
It is currently Fri Jan 10, 2025 4:37 pm
