Hot water system
Alliance
Hot water system
by Alliance » Wed Jul 30, 2008 11:01 am
I turned off the hot water to change a sink. When it was turned off again one basin in the house had no hot water. I guessed it was an air blockage so have turned off the supply, opened the taps and turned the supply back on. Any other ideas?
by htg engineer » Wed Jul 30, 2008 12:04 pm
If it is an airlock, you can backfill using a piece of hose - by holding over the cold and hot tap.
Is it just the basin where there's no water ?
Ball valve stuck ? gate valve sheered off ??
htg
