I have a technical question concerning the planned installation of an Active Solar Heating and Photovoltaics System to an existing property that is subject to a complete renovation.
The issue here and which I would appreciate any advice users of this forum are able to give, is that I already have installed into this large 3 bedroom property, a new combination gas boiler (a Worcester Bosch Greenstar Highflow 440 to exact) which currently provides hot water at 20 ltr/min and heating. This is more than adequate for my needs and succeeds in heating up the house satisfactorily. However, because I'm environmentally minded and I would like to reduce my fuel bills wherever possible, what I would like to do is install an Active Solar Heating System that would work in tandem with the Gas Boiler. My question therefore is: Is it possible to install such a system and if so, how would it work?
The problem I have of course, and which I would like advice about, is that I do not have a hot water cylinder (if I did, I wouldn't have installed a combination boiler). Although the house is relatively large, there is really no scope for installing a hot water cylinder anywhere and given that I already have a perfectly good nearly new combination boiler, I don't want to have to get rid of it and replace it with a new conventional boiler just so that I can install an aditional new active solar system.
As I understand it (and please bear in mind that I am a just lay member of the public and [b]NOT[/b] a plumber or Gas engineeer), in order to make use of an active solar system, it is essential to have a hot water system. With such a system, an electronic controller constantly compares the temperature of the solar collectors with the temperature of the water in the cylinder. Whenever the collectors are hotter than the cylinder, the controller switches on the system's circulating pump. A mixture of antifreeze and water is then circulated through the collectors and the cylinder's heat exchanger, heating the cylinder in just the same way as a central heating boiler. However whenever the collectors are cooler than cylinder, the controller switches over control to the gas boiler and the boiler then heats water in the cylinder in the conventional manner.
The whole point of acquiring a combi boiler was because I didn't want to use a conventional boiler and I don't have the space for a hot water cylinder, but by the looks of things, in order to achieve the result I want, I am going to have to have one. I don't know of any existing systems that are designed to work with combi boilers or how they might in pratice work. Therefore any advice you would be able to give would be gratefully appreciated.
As things stand, I suspect the only benefit I am going to get from Solar Cells is to have them generate my electricity.
