Two cold radiators
Myrtle
Two cold radiators
by Myrtle » Mon Aug 04, 2008 7:07 pm
Ever since moving into my house a year and a half ago, just two of my radiators don't appear to work. The whole system had been drained prior to my moving in so we re-filled the system and bled all the radiators. The boiler is on the first floor (in the bedroom believe it or not!). The two failing radiators are downstairs. One is in the bathroom, although the kitchen radiator that precedes it works fine. The other one that doesn't work is in the dining room, although the lounge radiator that is beyond it works fine. The pipes up to the valves get warm in both cases. If I try and bleed these radiators I get water straight away and no air. The valves appear to be standard manual valves from what I can tell - not thermostats and they have white cap over a lug that sticks up it that means anything to those who know. Is there something obvious I can try before getting the plumber in? All of the upstairs radiators and the one in the loft work fine. Cheers.
Steve the gas
by Steve the gas » Tue Aug 05, 2008 6:16 am
Hi Myrtle,
It's ok to have a boiler in your bedroom - it will probably be a room sealed appliance!
The no-workin rads maybe as simple as the valves are closed.
So open them (the lugs under the caps as you say) see what happens?
Hth
Steve
by htg engineer » Wed Aug 06, 2008 12:02 pm
Check all radiator valves are open, check pressure and vent the radiator.
Still no luck ? turn off all radiators apart from the 2 problem radiators, it could just be air in the system. Run the heating and see if it clears.
htg
Myrtle
Two cold radiators
by Myrtle » Wed Aug 06, 2008 8:14 pm
The valves definitely open. I will try closing all the others and running. Thanks.
It is currently Sun Jan 26, 2025 4:36 pm
