Gas central heating radiator not working.
frankino
by frankino » Sun May 06, 2007 2:37 pm
I have a problem with my gas central heating. When the heating is on and radiators are turned up fully(to give out maximium heat), all the radiators are scolding hot with the exception of the bedroom heater which is cold. I can feel the heat on the inlet pipework , but the radiator is cold. Any ideas?
Thanks in advance,
Frank
knight_eo
radiators
by knight_eo » Sun May 06, 2007 9:03 pm
could be an airlock or the valves are stuck do you have trvs on the rad if so the head could be stuck particulary so if its a myson trv
dave p
Re: Gas central heating radiator not working.
by dave p » Sun May 06, 2007 9:21 pm
check both valves are open. if it has a trv fitted remove the head and gently tap (the pin often gets stuck)
frankino
by frankino » Mon May 07, 2007 2:05 am
[quote="dave p"]check both valves are open. if it has a trv fitted remove the head and gently tap (the pin often gets stuck)[/quote]
Dave, many thanks for your response. Can you tell me , is the trv on the inlet or outlet of radiator ? And can you explain what you mean by "remove the head" . Please excuse my ignorance on this matter!
