Worcerster 24i rsf l combi
vaneeta
by vaneeta » Wed Aug 06, 2008 12:12 pm
The red light is on and we are not getting any hot water. there does not seem to be an ignition button. Please help!
by htg engineer » Wed Aug 06, 2008 9:40 pm
The ignition will be electronic, have you tried resetting the boiler ?
You need to find out what stage the boiler is getting to, for example does pump run ? fan run ? air pressure switch proven, ignition at burner ? etc etc
htg
It is currently Fri Jan 10, 2025 4:34 pm
