no hot water
toget
no hot water
by toget » Thu Aug 07, 2008 6:14 pm
worcester boiler when running hot water red light comes on when running water but water does not get hot than red light starts flashing
any ideas people.
AdamsHeating
What worcester is it and how often does the light flash?
by AdamsHeating » Fri Aug 08, 2008 12:00 pm
My friend recently had a very similar problem with old 28i junior combi. His red light flashed about once per second. Looking in the manual for that boiler it states several problems, but when he called out the Worcester Bosch engineer he said " it was the water control switch that had gone so he had to fit a new one", this was after testing a few other components.
Unless it's a low water pressure problem in the sealed system (that can be alleviate by opening the filling loop) you will find that you will need the help of a CORGI engineer who is able to test the parts and locate the exact problem.
by htg engineer » Sat Aug 09, 2008 9:02 am
As adamsheating says, the number of times the light flashes indicates what the possible faults could be. Try following the diagram in the back of the boiler instruction manual.
Does the boiler reset ?
htg
It is currently Sat Jan 25, 2025 2:24 pm
