cutting bamboo
tatmac
cutting bamboo
by tatmac » Fri Aug 08, 2008 9:20 am
i need to replace two pieces of bamboo kitchen worktop, this would require making two straight cuts across a piece of worktop. what is the best method of cutting, ie do i use a circular saw, or something else, i dont want to splinter the worktop. any help would be appreciated.
TheDoctor4
by TheDoctor4 » Fri Aug 08, 2008 9:54 am
Have you had a chance to look at the DIY projects section on:https://www.diydoctor.org.uk/projects.htm There are several projects relating to worktops that may be of some use to you.
tatmac
by tatmac » Fri Aug 08, 2008 1:49 pm
no, had a look, really just want to know the best form of making a straight 90 degree cut in a bambboo kitcken worktop, in order to get the best finish. thanks.
It is currently Wed Jan 08, 2025 4:44 pm
