by KartingDave »
Wed Sep 10, 2008 10:55 am
Hello,
Soundproofing a floor should be quite easy but does depend on the construction of the building, So a few questions to start off with.
How do you want to finish the floor?(carpet, laminate or other)
What construction is the floor?(timber, concrete or other)
What construction are the walls of the rooms?
When the building constructed?
The best and most versatile solution is to create a floating floor using acoustic R10 and SBM5 soundproofing mat topped off with Quietboard. But there are other solution depending on the answers to the questions above.
Hope thst helps.
