mysterious CFL bulbs...
Tomtom8
by Tomtom8 » Sun Aug 10, 2008 2:25 pm
I’ve got 4x50W CFL ceiling lights in my kitchen (recessed, so I can’t see the wiring or transformer), and they’re doing strange things – quite detailed, but the details might be important. First, bulb 1 blew. I took out bulb 2 and put it where bulb 1 had been, but this too blew straight away. Bought new bulbs and replaced both 1 and 2. Worked fine to start, but then after a few hours bulbs 2, 3 and 4 all dimmed and then went out, though 1 went on working. Turned off wall switch. When I switched back on later, all bulbs worked again, but then after a while 2, 3 and 4 again dimmed and died, leaving 1 lit. Again, after a while I switched back on and they all worked. Can’t get my head around how this is possible! Anybody come across anything similar?? :?
by ericmark » Mon Aug 11, 2008 11:26 am
I will guess on bad connections which can cause excessive heat. Due to fire risk I would not use the lamps until the problem is cured.
Tomtom8
by Tomtom8 » Mon Aug 11, 2008 1:01 pm
Ta. I'd kind of assumed the same thing, even if I can't imagine why certain ones should play up and others should be fine.
It is currently Sat Jan 18, 2025 5:49 am
